VIN number
nickharman
Im trying to get full details of my R4 to get parts etc
The VIN number comes up with R4 but says it was made in 2005 but in fact it was made in 1984
Other search sites simply deny the VIN is valid, but I am looking at a sharp photo of the VIN plate so I know it is correct
The car itself is in France and I am in London at the moment
Anyone know a good site to enter the VIN into?
Nick
I am afraid that all those sites will not give you real info as they do not cover old VIN numbers.
To identify your car there are 3 plates you need to find.
Oval plate where VIN number is, production number (actually serial number of the car - give you factory where your car is made and date when your car has made), sometimes colour code, equipment code.
There is engine plate somewhere around oil filter (for 1108 engine) on engine block.
Give you what engine you have and his production number (sometimes there are small differences on same engine but with older or newer production number)
And there is gearbox plate on one of the bolts that holds cover plate on gearbox.
You will find out model of gearbox and production number.
Hi Petak, probably a stupid question but how can you tell where a car was built from the no`s on the oval plate? I can`t look at mine at the moment as the car is covered up for the winter.
Cheers Simon.
Simon Knight...i believe that you have got your answer from link that jjad put.
I was little bit unkind presuming that everyone know how those numbers look like.
Production number starts with letter which according to renault's logic identify factory where car or engine is built
Here are mine plates
"oval plate" witch actually is not oval
On the left you can see vin number in two rows.
On the right (in oval) first number is model number 1128
495 is color code for my car
and last number Y124549 is production number of the car
Others numbers are some kind of equipment codes. I presume they are telling witch part of europe (or world) car is made for, what kind of upholstery car have, lower or higher interior equipment. But not sure. Just my thinking
Engine plate from my car
first number is engine code
second number is production number
gerbox plate
this one is not from mine car but from gearbox i would like to get for my R4
number that is written in a circle is gearbox code
number written in line is production number of the gearbox
Hope now is little bit more clear about all those numbers
Cheers!
A lot of information can be obtained from the VIN, a lookup through a so-called online VIN-checker only costs you money.
The plaque losange (rhombic plate) and the rectangular plate contain the VIN info, the VIN is also stamped in the chassis, left hand side on the mid cross beam.
The oval plate contains the factory model info and extra's and options and maybe more...
And there's a later plate model the plaque unique as Petak showed :) which is a merged version of the rectangular and oval.
Have a look on this site, its about Renault VIN explained but not completely.
http://renaultconcepts.online.fr/ressources/codes/codes-vin-auto.htm
It's in French but mighty google translate will do.
This site gives online Renault VIN info but again not complete.
https://vindecoder.eu/renault
Cheers, Joop
Thank you all for such detailed replies, I knew what some of the no's were but was interested to know where mine was built. Will check the production number for the letter code next time I get the car out.
Cheers Simon
can anyone decode the attached
Please?
I mostly require the year I got the engine is 1108cc
Hi
I'd get a second opinion, but I think it's 1984 - the 'E' in the chassis number would indicate that, plus the 427060 on the oval plate. (1983 models finished at 361751).
On the oval plate - 2370 = F6 van; 101 indicates Belgian specification/manufacture (?).
The engine - if original - will be 1108cc. If it says 688 on the engine plate, the compression ratio will be 9.5:1; if C1E, 8.3:1 - the latter engines were designed to run on 2-star. When these vans were new, the choice at French petrol stations was between 'Super' and 'Essence'.
I've had an F6 (1983) for the best part of 30 years - good luck with yours! They must be extremely rare in Australia.
More info on plates here:
As I say, see what other forum members say.
Hi
Certainly is rare - i have been a Citroen fanatic for years having owned 5 2cv varients since 1974 - this is a barn find was once a Belgium postal service van still in the original yellow never registered in Australia so the bureaucracy will be fun - lot of work though.
