Sage103
Gordon
 - Torphichen, Scotland
This started out as just a little pre-winter maintenance (even though the car is currently out of MOT and likely to be off-road until late spring) just to renew the antifreeze. However when checking all the joints I tightened the radiator temperature sensor a little and managed to produce a leak of new antifreeze. It still leaked after replacing the sealing washer so I decided to take the radiator out for a good check over. It seemed to be ok but I thought it might be a good opportunity to replace it and the water pump (which was weeping a little). I was quite surprised to find a new Nissens radiator on eBay for just under £50. And I already had a replacement pump from my early days of R4 ownership when I used to trawl eBay regularly for suitable parts.
But, as the second photo shows, I need to swap the pulley drive on the pump. It looks like it is a push fit on to the shaft which may be splined. Can anyone confirm that this is the case, please?
