- Bedford UK
I put the MGA through an MOT this afternoon to celebrate her 50th birthday, then I remembered why she has been off the road for so long.
She has a ballasted 6V coil, and the 12V feed from the starter has broken so I've set up a spare feed on the dash. Returning from the MOT she started missing at low revs (below 2000rpm) and conked out on the driveway. Switching the coil to 12V got her going again, but back to 6V and she'd fail once more.
A weak spark, but I've changed everything - distributor, coil, contacts, capacitor, rotor arm, ballast resistor. I've fiddled with the leads (the silly ones located to the distributor cap by means of a screw - I've cropped the ends of the leads to make a new screw hole).
Also it's temperature related - only happens when hot - maybe 10 miles driving.
I'm baffled. Anyone have any ideas or thoughts about what could cause temperature related spark problems?
I had a very similar problem with an MGB V8 fitted with a Mallory distributor. Took me 2 years to trace that to the earth in the distributor (really bad design on those).
ops: I'd hadn't realised they were on the same day!
