K kujo Enthusiast Messages 7 Mar 9, 2007 #1 what iff i directly get air in the carburator or i double the air what goes in the carburator over the air filter! will it make the car go faster?
T timinder Enthusiast Messages 45 Mar 12, 2007 #2 Not on its own, you'll need to increase the amount of fuel that goes into the engine as well, otherwise it will run too lean and tend to overheat. (there's a LOT more to it than that, but I thought a simple NO was a bit too short an answer!)
malcolm & Clementine the Cat Messages 4,643 Location Bedford UK Mar 12, 2007 #3 The Renault 4 already has problems with lean fuel mixture, so as timinder says adding more air will make things worse. (Welcome timinder.) It is possible to get another 10bhp by fitting a carburettor and inlet manifold from a Mk 1 Renault 5.
