- Bedford UK
@mr-reno-139 or anyone else with a good memory -
Someone mentioned that the crank sensors were often replaced when unleaded petrol came into use, and the new sensor had a yellow lead and retarded the ignition.
Now my Renault 5 TX has a yellow lead and has the symptoms of overly retarded ignition - it's not quite as quick as it should be and has a slightly boomy exhaust noise both on part and full throttle. I'm wondering if it might have been retarded from the factory setting.
I'm planning to mess around a bit but wanted to check out if the yellow lead on the crank sensor has any significance.
