Cornish4
Le Dazzleur
- Falmouth
Hi Tom. I've fitted a 32 IF carb to the GTL from a R5, and the manifold had a tapped hole for a brake servo vacuum pipe, so I used that. The hole is ahead and inboard of the carb flange, and there might be enough thickness of metal to drill and tap the standard 4 manifold there.
Regards, Brian.
Regards, Brian.
