Hi thereHi there Tomcat! my F4 had these from birth! but shouldn't be a big problem.If you have another one nearby,make a simple template
of the opening,have the glass made locally and buy the rubbers from aftermarked rubbers sold by the yard.
measure the thickness of the panel and make sure you get the closest size to fit over edge of panel.
My advice is to joint it at 12o'clock (less water will collect and stay at 12:00 -use some sikaflex or other to get it properly closed..
so no water seeps through.
Also Do use some paint to cover the cut-out you made or it Will rust under there!
-You may also ofcourse look for the orig parts on ebay/LBC or the scrappers .Shouldn't cost a fortune -Reid.
StuartCan photograph mine at the weekend if it might help...
Hi TomHi Tom, if you need any other photos, or dimensions, let me know.
Hi PaulDid have some of these I cut out of french van with frames sadly I think they got thrown out
Hi Paul
If you could check and see if you still have any would be appreciated.
Regards
Tom
Hi PaulSorry so much stuff got cleared from barn in short time and no idea what happened to them
How about morris minor van rear windows or similar
Probably easier to find
Hi WillTom, let me know if you want me to measure my side windows. They look like they were fitted from new. They make a big difference pulling out of junctions.
