mike4gtl
Mad many would insit upon
No i haven't put the wrong fuel in.
I have this idea of dropping a late 1980's Renault 5 super Diesel engine into an R4 (maybe F6) I would like to keep the R4 4 speed gearbox but i have reserved a 1982 R5 5 speed box locally if i need/want it.
What i want to know is, apart from the usual bracket making and cable ammending, how hard do you think it will be ????
Does the 1.7 GTD engine even turn the same way as an 1108 engine? Also the 1108 is an in line engine and the 1.7 GTD is transverse, will this cause any problems? what about with the gearbox?
I will probably have to make my own backplate for the bellhousing to attach to but thats easy. Will the R4 spigot shaft fit into the R5 crank (will probably use R5 flywheel)
Alot to ask i know but an R4 diesel - what a novelty
. You think you are buying a Saab with all that aero-technology and you get a bl--dy Vauxhall:smile:
