Hi all
Following the overheating and subsequent explosion of the radiator on my F4(845cc, 1985) I have been looking for a replacement..
I have found some online which are the correct dimensions for the car (with direct drive fan, not electric). Only problem is there are 3 reference part numbers but no explanation of the difference between each..
There are options for the 1123cc (7701348916) which sounds best as it is sized for an 1100cc, so should have adequate capacity for an 845cc engine.
Then there is a 'safari-export' version (7700572645) and finally a 782cc (7701348271)
Can anyone advise as to the difference between these part numbers (or where i might find that info) and which one i should use for my van..
Merci bien
Merci bien
