Hey,
I have been following some threats here but have not posted a lot. I have a problem now so here I am.
Last winter I have rebuild my 850 cc engine. Engine out and open, new bearings, seals and gaskets, liners and pistons, oil pump, etc... Engine painted, a lot of parts coated,… Engine back in the car and complete fitted with cooling, oil, filters,.... When I try to start the engine it is no problem; starts immediately. The only problem is the engine starts to leak big time because the sealing of the oil filter is pressed out.
Any ideas what can be wrong? I suppose the oil pressure is high because the oil is trapped in the oil filter.
I have tried to find out how the oil finds its way in the engine. It is sucked up by the oil pump and goes from there to the oil filter. The oil comes in on the outside of the filter and goes through the filter and mounting tube to the engine. Anyone an idea how it goes further or am I missing something?
Regards, Bart
my beautifull but leaking engine:
the pressed out seal:
Regards, Bart
