@Joolzy are the gasket between the intake manifold and the carb ok?
have you the reference of what kit you bought?
- starts worse without filler cap- Does it make any difference if you remove the fuel filler cap?
- As jcarruthers2 mentions above, it's critical to ensure that the arrowed pipe/restrictor/manifold connection/rocker cover are really clean (it looks as though your car - and perhaps all Portuguese GTLs - has a different restrictor system; on UK cars/vans the restrictor is in the pipe):
Could you post a few photos of your carb/distributor area?
It's a Femsa distributor - points maintenance/changing is much more of a hassle than with Ducelliers. There's an excellent page on them here:- starts worse without filler cap
- photos below:
re the distributor: what make is it? And how do I approach changing the points? Not come across one before with a metal plate.
the restrictor photos - the red one is what‘s on it and the silver one is what I received when I ordered one.
View attachment 29280 View attachment 29281 View attachment 29282 View attachment 29283 View attachment 29284 View attachment 29285
Great thanksIt's a Femsa distributor - points maintenance/changing is much more of a hassle than with Ducelliers. There's an excellent page on them here:
Changing Distributor Contact Points (renault4.co.uk)
Portugal so no icing problem hereNeed for engine to run, fuel and ignition.
if problem with fuel. Check if pump delivers fuel when engine stop. Take fuel line of close to carburetor crank engine if no to tiny fuel comes then you know if problem is before or carburetor. If no or tiny fuel comes check filters before pump.
If there is plenty of fuel coming then problem is in the carburetor. (Remember not get fuel on hot exhaustmanifold).
Dont know what climate you have but icing in carburetor throat can be a problem from +10degree C. When car halts take off airfilter and check down in the throat if some ice is visible then you know why engine stops.
if that’s the problem it often occurs after 10-30min driving car go worse and worse until it halts or you stop trying. And after car been standing 5-15min it starts like there is no problem (ice melts).
Is it worth trying this pipe system the other way round - i.e. rocker cover end to carb?Great thanks
Tried it just now and it ran worseIs it worth trying this pipe system the other way round - i.e. rocker cover end to carb?
(forgive me for copying your photo!)
Photo of usual set-up on this page:
Modification du circuit de recyclage des vapeurs d'huile (la4ldesylvie.fr)
Just a thought, and just checking - cylinder 1 is the one nearest the water pump (in your photo with the distributor cap off, the rotor arm is pointing at cylinder 4).Tried it just now and it ran worse
YesJust a thought, and just checking - cylinder 1 is the one nearest the water pump (in your photo with the distributor cap off, the rotor arm is pointing at cylinder 4).
Did you put a new gasket between the intake manifold and the viton joint? This kit just bring one, probably for the carburator side![]()
Kit de reparación carburador Zenith 28 IF equivalente
Kit de reparación carburador Zenith 28 IFpiezasautosclasicos.com
Yes that gasket is like new
YesDid you put a new gasket between the intake manifold and the viton joint? This kit just bring one, probably for the carburator side
That’s all clean.When you removed the fuel tank, did any rust come out with the petrol? Is there any chance that the filter on the fuel sender could be getting blocked by debris?
