JonathanT
Not normal for Norfolk
- Wymondham Norfolk
Hello all it’s been some time since I was on here .
My R4 has suffered problems with hot starts . However, when I change to the new hire octane E5 fuel. The problem seem to go away. However, it’s back with avengeance!
I made up a generous heat shield to experiment with and placed it between the manifold and the carburettor. I took the car for a spin round the block and then left the car with the bonnet shut to see what would happen. Turns out the problem is still manifest. The carburettor body was quite cool but the fuel in the pot was still boiling vapour was escaping and fuel was being pushed over the overflow clearly this is a dangerous state and I can’t allow this to continue. On my car, the fuel filter is on top of the engine. And I think this is where the majority of the heat is being collected so my plan is to fit an electric fuel pump and place it away from the engine itself then run the fuel pipe away from the engine up to the carburettor via a fuel filter
I have seen various in the past which involve a loop allowing the boiling petrol to be transferred back to the supply. However, I still see this as a dangerous situation as it’s not curing the problem it simply making the symptoms go away. I would be pleased to hear if anyone else is having problems and if they have any solutions to offer.
Jonathan
Jonathan
