Raising rear ride height, GTL.
Barney54
Mid Glamorgan, S Wales UK
My 92 Clan has had it's rear end, 'Dropped' by around 40 mm, by my reckoning. I'd like to raise it back. Is it possible to do this by marking the torsion bars, relative to their mountings, and rotating 'X' amount of splines, instead of using the threaded tool, that substitutes the shock absorbers? Also my outer suspendion arm mounts are showing some quite serious corrosion, are these easily replaced, I know the bushes need pressing in etc...I'd replace them complete. Cheers, Paul.
Morning Paul, Im new to R4s so there'll be better replies. Ive had a number of old VWs so understand your thinking re the splines but I think you'll struggle that way. La4desylvie has a good tutorial on this & mounts along with lots of info on here. I thought the tool & setting up looked a headache but I managed to cobble something together getting threaded bar & the shackle adjuster bit from toolstation. Its quite quick/straightforward to do once you get into it. Hardest part was hammering the torsion bars free again that had only been refitted 6 months previous with grease. Not sure about replacing the outer mounts in situ I had to drop mine out complete to repair the inner & outer chassis.
Thanks for the reply, I think a trip to tool station could be in order. The 4 sylvie sight is brilliant, highly recommend it. Thanks for the help, will let you know how I get on. Paul.
It helps a lot to substitute the shock absorber with the threaded tool, then adjust its length to what you did when you had fitted the torsion bar - or to factory setting if you haven't removed the bars. Suspension arm bushes try to push the arm towards the half laden posiion and this puts some strain on the torsion bar splines.
