About to get my first Renault 4, asking for advice!
Zaliago
Member
Poland
Hello Everyone!
I've been looking for a place to ask for advice before (possibly) buying a Renault 4 of my own , and I figured this may just be the best one.
You see, I'm not very experienced with cars in general, especially classics. I always had a fascination with older cars, but I never really had much of a chance to drive one, let alone own one.
But recently I saw an offer for a trully stunning R4 in my country (Attached in the photo), and for a decent price too! (22k PLN, so a little over 5k Euro)
And aside from the fact that the engine seems to leak quite a bit and a bump on the side, the car seems to be in a really good state.
But again, I'm not a super experienced driver/owner, so I wanted to ask for advice since I really, really do want to take good care of this car (if the deal does go through, that is).
So, is there anything I should look out for? Or something specific I should ask the owner about?
And also just, well, what should I expect? How much maintenance does a car like R4 need? And should I prepare in advance (like getting parts or specific products)?
Any help is greatly appreaciated!
Following on from my previous post elsewhere : given the presence of the starting-handle hole in the bumper, this car is almost certainly equipped with an early-style gearbox. This requires care when changing from 1st to 2nd (or vice versa) otherwise the gearbox can be ruined. The technique is called ‘double-declutch’. If you buy this vehicle read up about this online and practice carefully.
As ‘jjad’ says : chassis rust is the killer. There were, I believe, 800,000 R4s imported into the UK : our dreadful weather has finished-off virtually all of them. Look very carefully at the rear axle mountings coming off the rear chassis. If these break it is very difficult to repair them.
Those points apart, R4s are pretty well foolproof. This Forum is a good place to get specific advice.
The early 4 speed had a starter handle hole too. The bonnet on the car is shaped to fit the later front crossmember which was fitted to accommodate the extra length of the 4 speed. That one should be '68 to '73 with an 850cc engine, 4 speed dogleg first gearbox, and nice seats. They are my preferred Renault 4.
Thanks a lot! I'll definietly practise it once I get my hands on it!
The early 4 speed had a starter handle hole too. The bonnet on the car is shaped to fit the later front crossmember which was fitted to accommodate the extra length of the 4 speed. That one should be '67 to '73 with an 850cc engine, 4 speed dogleg first gearbox, and nice seats. They are my preferred Renault 4.
Amazing deduction! It's a '73 845cc engine, and the seats are very nice indeed, they're part of the reason why I like it so much.
I did also see that you had a simmilar one when I was doing research, so I'm glad I'm not the only one who enjoyes them a lot hah
Also, fun fact, it's classified as an Antique Car, hence the yellow licence plate, meaning ~90% of the parts are original, at least in theory.
In practise they aren't super precise with the counting, but still, most of it should be genuine, which is really neat.
If the chassis is as good as the interior, looks like a great find!
It'd be a good idea to get hold of both the Haynes and Autobooks manuals - they're extremely useful for the earlier cars:
This site is excellent too: https://www.la4ldesylvie.fr/
There are still a lot of parts around if you know where to look - particularly if you start with a part number, and the plate numbers under the bonnet.
It'd be worth checking out the source of the oil leak.
Does the current owner have a dog?
Best of luck with it!
Thanks a lot!
Yeah I'll ask the owner about it, but I talked with my brother who's a self-taught mechanic and he said it's likely the shaft seal, since the listing mentioned leaking from the shaft-side.
Unless there just is a hole in the engine, which I hope isn't the case
Oh, does that matter? I mean, there wasn't any mention of animal damage etc. on the listing, but I imagine this may be important in a different way, yes?
I was looking at the steering wheel - it looks a bit gnawed (unless it's the photo..)
Ahh yeah I see it too now
I assume it may just be the texture of the plastic? But the photos are not sharp enough to tell frankly so I can't be sure
Some useful websites for parts:
And, of course, French, German and Spanish eBay
Okey so, Update for the engine leak- It seems like the problem isn't the seal, but the Grease Cord (I hope that's how you translate it-) and it can't really be replaced without taking the engine out
The owner had it repaired once before, but it seems like it wasn't done well and so the car started leaking quite badly again.
Still, it seems like an easy enough repair? I assume a knowleagable enough mechanic could get it done without too much of an issue, I hope.
The car will need a tow truck though, since refilling oil every 20-or-so minutes for 500km doesn't sound too great.
Freankly it all seams quite straightforward, but at the same time I can't help but be a bit nervous.
Like, a part of me is afraid that because this car has so much history and love put inside of it, that even when I do buy it, I won't feel like it's truly my own?
And if I would want to do anything with the car, be it a new paintjob or some slight alterations, I'd mean erasing that history and love.
Parhaps I'm just overthinking it and in reality it won't be so bad, but I was curious if any of you also had simmilar worries while buying your own R4's
Could you tell us what the Polish term for the place the oil is leaking from is? 'Grease cord' is likely to be an example of L1 transfer.
Is there oil on the cylinder head? Could it be the rocker cover gasket?
Is the leaking coming from between the engine block and the sump (oil pan)? If so, is it the sump gasket?
Have you looked to see if there's oil coming from the sump (oil pan) plug?
Is the leak coming from the:
uszczelka glowicy cylndrow
(cylinder head gasket)
Or
uszczelka miski olejowej?
(sump gasket)
Or more likely the:
uszczelka pokrywy lanncucha rozrzadu?
(timing chain cover gasket)
which would require taking the engine out.
I didn't ask for the exact place, but from what I got it's somewhere around the gearbox/shaft?
I mostly just wanted to know which part would need replacing.
Also, from what I gathered the "Grease cord (or Tallow Cord)" is essencially just the seal for the shaft (or a pump?) that a bunch of older car used to use, so there's that I suppose?
I wish I could give more details, but again, the car is 500km away so I only know what the owner mentioned in our brief phone call and I don't want to bother him too much right now.
If it's helpful in any way, the polish term for the cord is "Sznur Łojowy" and it looks like that
Is the oil that's leaking engine oil or gearbox oil? Gearbox oil has a very distinctive smell.
I wish I could tell you but no matter how distinctive the smell is, I can't smell it from across the country-
I'll remember to ask the owner once I get in contact with him again though
There are no oil seals on these engines, neither conventional nor rope ones as on your picture. There is a slinger and a series of ridges cut at an angle, immediately in front of the front main bearing that encourage the oil to be thrown back as the crankshaft is rotating. Leaks from the flywheel end of the crankshaft are either due to sump overfilling, or sludge build up on the crankshaft front end. Or more serious reasons like worn main or thrust bearings, of course.
Black dashboard and steering wheel indicates a post-1973 car so the bumper with the starting handle hole (pre-71) may had been fitted later. Would be nice to see the oval plate to check production year.
Well, this is quite curious then.
The owner definietly claimed to have had the rope seal replaced a while back, which apperently fixed the leak problem, only for the issue to return again after ~two years.
I assume that he wouldn't just straight up lie about it, and he seems to know a decent bit about R4's (he owns at least two of them) so I would also doubt that he mistook it for something else
He did mention having an additional engine and a beige dashbord, so he likely got the parts from at least two cars and just put what he thought was best in the actuall car.
The listing also states that the car was made in '73, but it was also imported from sweden 6 years back so it's possible that some of the paperwork could be a bit patchy.
