Bflorian
- Serbia
Hello, I've recently bought a 1990 Renault 4 GTL from a junkyard(no papers, just a rally car project), and I have really bad compression problems, I measured the compression on all four cylinders and its horrible: 1: 5Bar, 2: 3Bar, 3: 4Bar, 4: 6Bar. Soooo, it's time for new rings I think but I have a problem, the main one, what kind of/ size rings does it use it has the 1.1l(1108cc) cleon fonte engine. I've read that it uses 3 rings witch are 70mm and 2.0 mm top + 2.0 mm second + 3.5 mm oil, but locally(kinda) in Serbia and even in Hungary I can only find rings in a similar size in 70mm, 1,75mm top, 2.0mm second and 3.5mm oil. Can I use that? Or what should I use?
