Hello,
I'm rebuilding an 839-06 engine, but am pretty new to these engines -and am in need of some guidance.
I've taken the head off, and it looks like one of the pistons shattered and there was water sitting in 2 other cylinders for who knows how long. I can't for the life of me find any 55.8mm sized parts-but there are lots of the 845cc parts. Would there be any issue with just replacing the liner and pistons with ones for the 800-01 engine? As far as I can tell it looks like everything will fit, except having to drill/resize the pistons with a 16mm pin hole.
Also, I had some trouble taking the head off, I ended up cutting a 14mm socket in half to fit under the rockers. I couldn't figure out how to pull the rocker shaft out to get the rockers out of the way. Do you need to remove the rockers before taking the head off, if so how? Maybe a special tool?
and then discovered the thread and also discovered that the shaft was actually 2 pieces meeting in the middle.
