billythefish
The other day after having the R4 tuned, apparently the emissions should be around 4.5% at idle but mine are 6% the mechanic stated that turning the mixture screw either way made no Difference, so he suggested I should buy a new air filter as mine was pretty grubby.
Now that's when the problem came to light because when I removed and measured it, the measurements were height 55mm x diameter 180mm.
I have been to most of the older shops that I know and on the internet but cannot find any filter for a 1971 R4 of that size, both the ones that I have found are over 200mm in diameter.
Could it be that a previous owner in the past switched the air filter and unit from another earlier or later R4 onto mine?
:eek:
:eek:
