Strmoslava
- Banja Luka, Bosnia and Herzegovina
Hi guys, I noticed my brakes got worse over time and realised there should be leaking somewhere in the system because level of brake fluid was going down, but really slow.
Tried to identify problem by checking all the pipes and cylinders and in the end it is a leak from down under of brake fluid reservoir/container.
Leak is located at the top of master cylinder and when I move reservoir it leaks more.
I am not so much involved into this part of brake system, so is there option of changing brake fluid reservoir or I should change whole master cylinder?
It's Renault 4 TL model.
Is it posible to place GTL cylinder to TL?
Friend @Merkator Fontana and I have a lot of parts for GTLs, but this old boy doesn't have TL donor.
I will make photos today.
Thank you.
Thank you.
