Engine size identification
What do you mean "camshaft bush"?
Keep in mind that, even after fitting the R4 camshaft and deleting crankshaft pulley, cylinder head will need modifying to accept the water pump at flywheel end.
Or you might want to take a look at replacing the head with your original head from the 1100cc you have.
I am going to use the 1108 cylinder head since that makes life a lot easier
The camshaft for the 1397cc engine runs directly in the cast iron block. I intent to use the 1108 cc camshaft and it needs a bush at the pulley end cos the journal is smaller. My guess is that the pulley end bearing has lots more work to do and it was decided to make make it smaller and use a bush so that it can be replaced when worn
