- Bedford UK
Worth some notes about how to fit a cheap temperature gauge as there have been questions recently. I've got an overheating issue to diagnose and I'll need a temperature gauge for that. I thought about throwing a thermocouple into one of the hoses but gauges are cheap so decided to go that way. I did no planning or research before I bought the temperature gauge and there may be more suitable ones available.
I went really cheap and bought this one:
The sensor on the 747cc engine (and I think all Renault 4 engines including 845cc and 1108cc) has a M18x1.5 thread but all the cheap temperature gauges have a 1/8 NPT thread so an adaptor is needed. On the early engines the temperature sensor was placed in the waterpump and for the GTL there will likely be a threaded blank in the waterpump that can be removed to fit a sensor. I bought this adaptor:
The thread in the adaptor looked about right but the sensor was too big to pass through the hole in the adaptor. I drilled out the part after the thread to about 10mm leaving a gap around the sensor. The sensor doesn't stick out past the adaptor which isn't good. Normally you would want the sensor to stick out into the cooling water. Hopefully some water will get around the sensor. The sensor part didn't screw in fully to the adaptor possibly because there is a taper to make a seal. I smeared a bit of sealant around the sensor thread and screwed it in to the adaptor as far as it would go. The adaptor itself screwed in perfectly and it came with it's own copper washer.
I'll follow this up with a part 2 post when I actually fit it, then a part 3 where I find out if it works or not.
