These cars need the ignition system to be well serviced - make sure the points are clean and correctly adjusted, and that the ignition timing is correct before doing anything else.
A common problem is the carburettor choke doesn't fully open (maybe the cable slips or has been badly fitted). You can check by taking the air filter off and looking down the carburettor to see if the choke is opening fully.
