PS: the 22 mm measure comes up just to close the flap valve in the carburettor cover, may be it should be a little bit less, so as to close the valve properly. An other question: There is no mixture screw in the Zenith 32 IF?YES there is a mixture screw - it is located in a small recess where the water feed (from the water pump) enters the manifold of the carb (in the manifold itself.)
Hello Pavel if you haven't found it yet, here is the mixture screw.
Hi Angel, so I tryied to set it today. I made out of a rivet this dipstick. It is a little bit longer, than the open valve. When I set the dimension 22 mm, the lid is just closed, as shown in the picture. Is it so right? Pavel![]()
You have to carefully bend the tab that rests against the accelerator pump rod in order to achieve the correct setting.
It has been almost ten years since we discussed this, but fortunately the method of setting remains the same.
