Davemassey1983
- Pembrokeshire
Little more done today, removed the fuel tank and I was going to remove the rear suspension but the rear shock bolt is seized on so I guess that’ll need cutting out!
Also the rear brake bias valve? Holder has seen better days!
So I made a start on the body work, managed to get the drivers rear wing off...what an absolute faff that was! And removed some of the lower c pillar metal so I can get a good look at what needs to come out, made a patch panel up (I’m not a pro and I know it’s not 100% perfect but it’ll do the job!)
Next thing will be to cut it to shape and finally get some new metal welded in there!
