- Bedford UK
I've been messing around with soundproofing on the Gordini. The latest experiment was putting heavy layer and foam on the cabin side of the bulkhead (the most important treatment in modern cars, but missing on the Renault 4). I've used a rubber floor mat spaced off the bulkhead by 12mm foam.
Soundproofing on the bulkhead transforms the car! The noise from the engine is quite a broad spectrum so you don't really realise how much there is until you take your foot off the throttle and press the clutch in at 70mph. On the Gordini the soundproofing vastly reduced the level of that noise and surprisingly it also got rid of a couple of annoying booms.
The only other thing that seems to make a difference (but the effect is not all that noticeable until the bulkhead has been treated) is foam under all the existing foam mats. This is the other major bit of soundproofing modern cars have, and is an easy modification to make to the R4.
There's a little detail on http://www.renault4.co.uk/gordini-soundproofing.htm and notes about a couple of other things I've built in. (note vans have their own set of issues so might not benefit so much.)
Makes the car so much nicer up to 50mph (after that I still have a problem with wind noise, but I plan to crack that).
