Sage103
Gordon
- Torphichen, Scotland
This morning, after 10 years of very intermittent restoration activity (and retirement didn't help as it coincided with becoming a grandparent) I finally set off down the road for the MOT station - but didn't get very far, or beyond second gear, as a howling noise started to come from under the bonnet. My first thought was a slipping drive belt given that I had just replaced both a few days ago - although it wasn't the typical slipping belt kind of screech. So quickly returned home and tightened the alternator belt as it could take a bit more tension. The main belt felt ok.
Set off again and same noise again. So cancelled MOT and had another look under the bonnet. Revving the engine while stationary doesn't produce the sound. There's nothing to indicate that the water pump is failing but there is some play in the idler pulley. When I returned home the second time I free-wheeled part of the way just to check if the noise was coming from the clutch or gearbox but putting it out of gear didn't stop the noise. When the car stopped so did the noise.
So suspicion is on the transmission - perhaps the clutch release bearing? The only items which I have replaced up front are the all the suspension joints, the brake hoses, the outer CV boots, one gearbox driveshaft seal, and the gearbox oil. I did adjust the clutch as it was only biting at the top of pedal travel. It doesn't seem to be slipping but I do have a replacement kit standing by.
Any suggestions would be much appreciated. It is a 1986 4GTL.
