Richnd1974
- Bournemouth
I've noticed the dreaded grot has appeared in my boot, apparently common where the seat belt mounts were fitted on later models, what's my best approach to fix, looking from the outside in the outer arch is solid no flex or rot, just appears to be on the inside, I can't find a panel that looks the same, would it be acceptable to cut out the rot and weld a new plate in place, assume that it might fail its mot as is unless I remove the seat belts or is this something more involved
