Keep the pistons and con rods in the order they came out or mark them so the bearings go back on the same crank they came offThe sump came off yesterday to expose the crankshaft and bottom of the pistons. I'm not too sure what to do next! I think I'll probably try to loosen the pistons and push them out.
The liners will probably be dislodged, but they need a good clean anyway. View attachment 10520
The crankshaft can't turn freely and the only way I can move anything is by smacking the clutch with a piece of wood and a hammer
Keep the pistons and con rods in the order they came out or mark them so the bearings go back on the same crank they came off![]()
Thanks for that Geoff, I'll be getting a puller tomorrow-one that can pull a bolt! I can feel a very slight up and down bit of movement in the gear, maybe 0,10mm or 0,20, but I'll try to get it more exact...
The workshop manual says the clearance between the gear and the sleeve should be between 0,15mm and 0.55mm. A pretty wide tolerance.
