Hi. We have a spanish GTL, and the two bolt holding the rocker cover on are quite different. One has a hemispherical"washer" which spreads the bolt load onto the cover. The other has washers and rubbers which must do something similar, but not as well as there is a small but persistent leak. As there will be someone out there who knows the truth, can they confirm that the domed washer is correct, and if so has anybody got a spare so that I have matching pair. If not can someone supply what should be there.
Thank you.
Thank you.
