Renault 4 full resto
This is lower part. From outside. Under the booth
This is upper part. Inside the booth
Thanks a lot very helpful!
After a three month summer break i continued from where i left. Shell is now practically rust free
194027039_483736806288325_1413687834523828483_n.jpg 244179900_254805773229927_4921996483569680445_n.jpg 244345718_1019814002147863_432296141633481912_n.jpg 244371324_546274186440677_1683159895489633687_n.jpg 244449435_454842322521349_1420231882091701931_n.jpg 244569734_1206034556564880_1789959395389142401_n.jpg 244648851_394206392329790_4879565057098533447_n.jpg nap hat.jpg nap hat.jpg rear.jpg
What did you do for the roof gutters? It's a particularly hard place to fix.
When i have needed to repair a gutter i have used a donor piece which goes into the roof about an inch and joggled the edge so that it goes underneath at roof edge and sits correctly,this gives a strong easily welded joint and is easier that rtraying to but weld. I do it this way as it being easy to hide in the roof area than to get a good appearance at the gutter. I did one whole side on a split screen VW once and you could not tell once completed and headlining in.
The roof gutter was not damaged as only underneath it there was rust, so gutter remained untouched, in the last repair above the tailgate hinge i have rot on the gutter(haven't repaired it yet), what i usually do to repair gutters is to use a metal round bar shape/grind as close as possible to the factory shape and hammer sheet metal to give it shape.Hope that makes sense.
More repair on hinge rot,inner side and outer side sheet metal repair.
Nice progress and workmanship!
From Sweden myself so used to rotten metall due to salted roads and long snowy winters. It seems like Renaults here was given a serious rost protection before they were sold and the owners top it up during lifespan. All my cars seems to survive rot death better than a lot of cars from south Europe. Usually it's the other way around.
Very impressed with your skills and stamina. Would like to see more from how you make the new panels. What tools you are using, how your jigg is bolted to chassis etc etc.
Are you born and raised at Malta or moved there, is there a lot of people renovating on the island or are you fighting alone.
Nice work and keep it up.
Thanks alot for your comments, i dont have much tools just the basics hammer/dolly,a good vice and a self made heavy duty bender on it, a mig welder, dent puller,spot welder and a shrinker/strecher whis i am still learning how to use.
Most of the panels i buy from cipere and demarco parts.
I am Maltese and there are alot of classic car enthusiasts here but the Renault 4 isn't a favourite here.Most have a following on classis Fords like the Escort mk1 and Cortinas. Having said that there is a particular Maltese mechanic that has an impressive collection of classic Renaults.
As regards stamina believe me sometimes i am exhausted/bored its a never ending story of rust repair on and on again but i have been there before so i know/hope i will survive :)
But then again hope is the mother of fools :) Ciao and stay safe
"As regards stamina believe me sometimes i am exhausted/bored its a never ending story of rust repair on and on again but i have been there before so i know/hope i will survive
Ciao and stay safe"
This is what I mean with stamina.
Think more than just me want to see more of the metall shaping. Looking forward to next update
