petak
- Vodice, Croatia
Well, ladies and gent, it seems that my problems are solved.....
Is it because better weather or something i have done, can not say but car is working fine now.
Story behind this words.....
After i have changed plugs have went on long trip to Zagreb and back
https://www.google.hr/maps/dir/Vodi...63899!2m2!1d15.8326343!2d45.8188512!3e0?hl=hr
Mostly open road and last 50 km is highway(motorway), driving 70-90km/h on some parts even 110km/h.....very easy and relaxing drive
In Zagreb i visited an older guy who is working on carbs (among other thing he do) to see what he will tell me about all settings on my car.
I was more or less aware that there would not be much things to do but wanted to talk to someone who has many experience with old cars so i can "get filing" for right setting.
He first checked dwell angel, and rpms at idle, then with strob light timing (without vacuum), and told me that all is perfect. Set as it should be. Checked vacuum pump.
Then he inspected old plugs and pipes around carb, and removed air filter box. looking inside carb. Turn it up few times. All was alright. Did not have anything to do on this part.
He mentioned that my gas pedal wire is to tight, adjust just little bit and show me how much play wire should have and still be tight.
And final thing he done was exhaust analyser. Turn mixture screw to get CO at about 1% (CO was 0,5% on my way to Zagreb). His comment was that from his experience at that position car is working best. Tested CO at high rpms and CO jumped little bit over 1% but not more.....He was very happy about that
No more juddering. I can go down below 60km/h in 4th gear at flat road and it works fine. Car is accelerating nicely aldo it seems that has some struggle between 90-100 (or is it just me triing to preserve my car - it start to be noisy at that speed)
Will not bother with it any more......this is how it should be....
My journey back was nice and smooth....
Made 450 km from Zagreb and still have 1/4 of fuel tank to empty - according to indicator on dash board.
I know that it is not precise and that i had open road so consumption should be lower than in town, but it looks promising.
If i manage to get 450km on 26-28 liters of petrol i will be satisfied (that would be 45-50MPG)
It was long and hard learning curve about carb, timing, points but i believe that now i know how to set all of these parts and have "filing" about it....
Thank you all for sheering your knowledge, expertise, experience about this matter.... helped me a lot to get it almost right.....
One picture on my way to Zagreb between Obrovac and Gračac...long steep uphill and downhill over Velebit mountain with hard corners and road that is carved into Velebit mountain.
