Hi everybody,
recently I decided to make a test on the rear door, considering I still really don't know how to correct the little holes due to rust, I wanted to see if I could apply this famous filler primer on my Rustol whithout problem...
The rear door is damaged inside, I will have to cut the rusty areas and make patches in steel sheet, so if my test is a disaster, it doesn't matter
I bought a gravity spray gun with 2,5 mm nozzle to make good job, then I started to sand the Rustol with 240 dry paper to improve the adherence of the filler primer:
Here is the product I used, the Raderal 3508 from Spies Hecker, I spayed the rear door of my 77 in the same time than the fiberglas wings and inner wings of my GTL:
After 2 coats with about 15 min between each one, the rear door is now primary coated, and the good surprise, contrary to the speech of the seller, the Rustol doesn't peel off, all seems to be ok
And the famous result I waited for is that the holes disappeared under this "liquid filler"
After fews days I sanded it with 240, and then 400 dry paper before applying the final coat of PPG primer, it is now ready to paint, I hope it won't have reaction in long time, actually none fault is present...
This saturday I decided to make the same job on the roof, so I did the same as the rear door:
Some holes are still present but I think when I will sand the primer, its thickness will allow to remove them.
