Hi guys,
Thanks!
I know that the clamp is missing, but I would expect that even without the clamp, the distributorbase would have a 'solid contact' with the engine. But I have no reference experience. If you remove the clamp, is your distributor as wobbly as mine?
Edit: maybe it seems like that partnr. 4 is missing. Will check that out..
because the distributor housing is a loose separate part, only attached to the engine by a gasket, clamp, washer and nut, and then driven by the small off-centre distributor drive shaft.
JoopLooking really FANTASTIC! Very well done!Howdiho,
Body got her final layer of clear, in the end of the build I will polish & buff out the orange peel.
My buddy Dick.
And for something completely different, testing the console lightbulbs
Cheers!
