Jurjenz
- Groningen, Netherlands
Finally had some time to remove the starter. I had to put aside the steering bar and the airfilter housing & upper engine mount. It was fairly easy to remove the starter. I hope the reverse is also easy
Looks like the relais on the starter above is non-serviceble. Looks like an inner spring has set loose? Also the inner plastic lever in the starter has worn badly, so I think it is a wise decision to order a fancy pancy new starter.
Maybe you can help with one question? I see new starters can be ordered with two turning directions. Spinning clockwise and anti-clock wise. I have an 845cc Billancourt engine. Which starter do I need?
