Vans finally approaching booking an ITV date, classic insurance here in Spain is not as straightforward as it used to be, policy stipulations now require that you need another car under 20 years old insured in your name, not so straightforward if its your only car……but its done
Fuel sender had failed in the time since last post, changing that currently, dropped tank yesterday, new sender from pizasauto is the correct one but needs holes drilled for the three small nuts that clamp it into the tank itself (don't know if this is a fasa thing), bought 4 new tyre to go on, getting rears fitted today while vans up in the air for sender. then tracking, fronts changed and ITV. Will post photos of the van finally on the road hopefully in the coming weeks.
Not made for a 4 but the Ondine, Gordini, Dauphine FASA built Renault had these fitted, couldn’t resist as a final touch for the F6’s rear door, teaser for the finished van on road photos which are becoming closer at long last,
As bought
After little attention, ready to go on
