Homegrown Garage Green One -75
I like seeing these pictures because an R4 is a real workhorse and jack of all trades.
Reminds me of how I drove my first R4, commuting distance was 200 km per day and then all the other kilometers. Parachutes in the back and everywhere through Europe to airports for skydiving and objects for BASE-jumping.
Keep up the good work
10000km since engine rebuild so first oil service. This time she got 2L 15-50 Mobil1 fully synthetic (from the time Mobil1 was best), and one bottle in the car for fill up.
Seems like my homemade magnetic oil plug made a great job, there was some magnetic slurry on it when I drained the oil ( probably from the new piston rings). Took the slurry between my fingers and nothing big enough so I could feel it .
New Mann filter was also in the deal.
Otherwise GreenOne behaves great 7000km this year without any big hiccups.
Hade to replace clutch wire and rebuild some because it has a square box and wire was for round gearbox.
I also grease the driveshafts when needed.
Today she was tool carrier when I helped my father fix his tractor.
I didn't know about the mil. Why is it 10km and not 1000km? But I am easily confused. I set my sat nav to read in metric because I got confused by the alternative units. It used to say 'turn left in 1 mile', then a little later 'turn left in 800 yards', then 'turn left in 250 feet'. I wasn't able to figure out the conversions fast enough and would end up turning right. The other thing that has been confusing me recently is the French use of dN/m. They'll say torque to 0.3 dN/m instead of saying 30N/m.
Good to hear the car is running well and performing R4 duties.
I learnt about the Swedish mile the hard way - I went for a walk in the late 70s with a friend who, when I asked how far we'd be going, said 'Oh, a couple of miles or so'. It turned out to be 17km....
Finland, Sweden and Norway had all a mil (we hav always been close neighbors or same land) it was mostly between 10km to 11,6km depending on land and region in land. When beginning of Si system we adapted our mil to be 10km so it became compatible with the meter.
I think all road signs where in mil until 30-40 years ago, so when I went to school we learned that one mil is 10km and 10000m.
I think cos our countrys is quite big it vas convenient to use mil instead of km.
In august clutch cable said i don’t want to serve you anymore.
Took me home starting on first gear and clutch less shifting to fourth gear.
Could only find clutch cables in france (sheep but high freight cost) cos my car have square box and long clutch cable, round gearbox have other hole spacing and different position so I made an steel adapter so i could use round box cable and lever mechanism. IMG_3171.jpegAdapter on the gearbox
GreenOne start taking in water when it’s raining. It comes in on drivers side up high under the instrument cluster. Seems like its not from the windscreen seal. I thought maybe the drain from fresh air went was clogged and water coming in that way, but it wasn’t clogged. Have no clue actually.
Anyhow I bought a lot of spares to the R4s some years back. Now I start put on new front shocks. TWR from Autodoc. Dampers I replaced was red (maybe Koni), not totally shot so I keep them as spare.
Haven’t tested them yet other than rock car on garage floor and that seems good anyway.
Very quick and straightforward to change front shocks.
Tools used:
Car jack, jack stands, 3/8” and 1/2” air wrenches, 17mm socket, 17mm wrench for wheels, lower and upper damper nuts and bolts. 11mm socket and 11 mm wrench to remove the swaybar. And when mounting new dampers top nuts was 14mm.
Still haven’t been able too solve the rain water problem.
Studded winter tires are mounted for snow season.
Needed to go terrain driving since my fathers “logg trailer” broke down in the woods. The boggie had fallen off the frame, so trailer hang behind the tractor fully loaded with loggs and no wheels.
I brought some tools, coffee, brain and muscle.
One hour later loggs was unloaded and boggie back on the trailer, reload an drive home.
Actually very impressed by the capacity in terrain can’t compare with my Niva but no new cars had been able to get all way to the tractor.
Let of some summer tires when I was passing.
