Okay, since the last post a lot of things have changed.
The last picture I posted shows the car with the taken care of-parts already in the epoxyprimer and a coat of filler. In the end I decided I wanted the whole car to be sprayed with filler to avoid colour-differences between the parts that were covered with the white primer and the parts that were still in the original colour. So therefore I bought another can of filler. That I sanded down with grid 600.
First I sprayed the bonnet, doors and the backlid in the orange paint. It turned out to be a disaster. I got orange peel all over. I kinda thought about it, figured out I would have to apply one thick coat of paint at once, not several thinner coats since that 2pack paint doesn't stay fluid for very long, actually, as soon as you spray it on, it's pretty much not flowing anymore, so when you apply more, the drops of paint don't merge with eachother anymore and what you end up with is an orangepeel finish. So I sanded all that down again with grid 600, then did it all over again together with a friend to make sure we did it right. That turned out pretty well actually!
Then we also did the body and we did a good job on that one as well but after a good look I found out some parts were still only covered in a very thin coat of paint, so I decided to get me some more paint and be bold once more. I sanded the whole body down again with 600 grid and repainted it.
The first coat was pretty good, had a few drippers but not too bad. The second time I got a little overcourageous and had a few more drippers and a few very bad ones along the total length of the panels too. I will have to sand them down and polish those parts again. One other kind of little issue is that you can see the sanding marks through the final coat (so the sanding i did between the two colourcoats). That kinda sucks but isn't too bad either.
I installed the pedals and the backwindows. I also applied the seals between the body and the fenders.
Here's some pictures of the whole thing, as well as some closeups of the finish and the drippers.
Also, I think it's pretty cool that I have a modified wheelarch!
In other words: check out the repair I did in the seatbeltattachment-area in the back of the car, it nearly looks like it's straight from the factory but reveals a slight change in design
I'll keep you guys updated!
Greetings,
Rutger.
